[ICEM] Prism layers in solid zone ICEM CFD
Old   November 24, 2024, 13:34
Default Prism layers in solid zone ICEM CFD
Arun raj.S
arunraj is on a distinguished road
Hi all,
I am working on conjugate heat transfer. I have two zones in my computational domain: one solid and one fluid. The fluid zone is rectangular channel surrounded by solid zone <wall with some thickness>. I am currently trying to create Prism layers in fluid zone. However, at the fluid-solid interface, a surface common for both solid and fluid, the Prism layers are formed for both solid and fluid in ICEM CFD. It is weird as Prism layers are needed only in fluid zone. How to solve this issue? Kindly provide some detailed explanation.
arunraj is offline   Reply With Quote
Old   November 25, 2024, 09:27
Gert-Jan
Gert-Jan will become famous soon enough
In Setup mesh (second icon in the ribbon), there is a long list with your volumes and all boundaries. There are tick boxes that give you control on which volumes and boundaries are included in the inflation (or prisms) generation.
So, if you don't want inflation in your solid, then untick that volume.
Gert-Jan is offline   Reply With Quote
Old   November 25, 2024, 10:57
Arun raj.S
Thanks mate. I did and got it.
Old   November 25, 2024, 14:56
Gert-Jan
I never use Delauney. I always use Octree and it always works.
Can you share a screenshot of the long list with settings for volumes and boundaries?(you can add a picture using "Go Advanced")
Old   November 26, 2024, 02:17
Arun raj.S
Yes, mate. its working for all meshes. I did something wrong previously. I have a followup question. When i do mesh check operation in ICEM CFD, i didnt receive any errors but i received the following problems.
. Multiple edges
. unconnected vertices
Can it cause any problems in solver?
Old   November 26, 2024, 06:39
Gert-Jan
I think it depends on the solver. Better check it yourself.
I always use CFX. This never complains about this, if I remember correctly.
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 16:02
ICEM - Prism Tool Problem carpe85 CFX 0 February 10, 2009 13:25
Rotating solid zone Rajesh FLUENT 0 May 17, 2008 06:44
