[ICEM] meshing wing trailing edge problem
Old   January 16, 2025, 15:49
Default meshing wing trailing edge problem
KG
kg_059 is on a distinguished road
Hey everyone,
i am trying to mesh a wing. the trailing edge is coming out a bit fuzzy (picture 1). The wing is modeled as a fluid wall (see picture 2), so it should not be filled by a volume mesh. Thats why I do not really get why it is so fuzzy. I tried to use smaller and smaller elements but the "fuzziness" stays.
Does anyone have a tip how to fix this?
The geometry of the wing consist of two curves at the root and the tip each (upper and lower side of the airfoil), as well as the leading and the trailing edge. So the wing geometry consist of two surfaces in ice. The trailing edge also is just one curve, so perfectly sharp trailing edge is assumed. Maybe I need to "give" the trailing edge a defined thickness as it would be in real life?
Thanks in advance for your help
kg_059 is offline   Reply With Quote
Old   January 28, 2025, 10:16
siw
Stuart
siw will become famous soon enough
Have you adequately defined connectivity of your curves using Build Topology? See this ICEM CFD video https://www.youtube.com/watch?v=bhE04cJ3X4o
Are you making the surface mesh via the volume Octree method first and then deleting the volume elements (then check and smooth the volume elements). Then recreate the volume with the Delaunay method (with TGlib, use AF), check and smooth. Then build the prisms. This is the best process for the tetra-prism and has been written here many times (but difficult to search for possibly).
siw is offline   Reply With Quote
Old   February 3, 2025, 05:13
Gert-Jan
Gert-Jan will become famous soon enough
You need to look fot "thin cuts".
Either in this forum or in the ICEM Help.
Gert-Jan is offline   Reply With Quote
Old   February 19, 2025, 13:39
Default How to define a thin cut
Bernd Brasas
IC_MAN is on a distinguished road
In such a case, the thin cut is the best choice. Make sure that you difine minimum two different parts for the wing and put all curved and points in another part.
YOu find this option at Mesh > Volume Meshing Parameters : Define thin cuts
(see snapshot)
The edge criterion is a global parameter with an effect on the whole model hat canbe reduced from 0.2 to 0.05, if a specificpart cannot be defined.
IC_MAN is offline   Reply With Quote
icem, mesh, wing
Trailing edge meshing -NACA 0012 Sony107 CFX 3 December 13, 2024 05:56
[ANSYS Meshing] Wing leading edge curvature meshing problem Alexia166 ANSYS Meshing & Geometry 2 April 21, 2021 04:29
Meshing near leading and trailing edge of propeller surajp92 STAR-CCM+ 1 June 1, 2017 01:40
wing with sharp trailing edge mesh through extrusion Hybrid Pointwise & Gridgen 18 February 9, 2017 10:31
trailing edge problem Kuo Wei-Jen Main CFD Forum 2 April 14, 1999 10:09
