[Workbench] Automating Geometry and Meshing
Old   January 19, 2025, 12:34
Default Automating Geometry and Meshing
podj63 is on a distinguished road
I have spent many hours trying to figure out where to begin with this problem but I am struggling to find a way in.
I have a large number of coordinate files, each are to be imported into design modeler, have a C-Type Domain built and then imported into meshing with my specified requirements then simulated. However, when trying to use the ANSYS journal files, it shows only opening the geometry and closing it.
I was wondering if anyone could provide guidance on how I can fully automate this process as I need to run a batch job of hundereds of geometry configurations to build a dataset. I am not sure if I need to incorporate js scripting or if there is an easier way for me to go about this.
Thank you kindly for the help.
podj63 is offline   Reply With Quote
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
[ICEM] Problem Meshing Asymmetrical Geometry Madhatter92 ANSYS Meshing & Geometry 1 December 23, 2017 06:56
[ANSYS Meshing] CATIA Geometry Generation and Meshing danielsullivan ANSYS Meshing & Geometry 0 April 3, 2017 22:11
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
