[TurboGrid] Mesh aligned with the flow
Old   January 24, 2025, 08:49
Default Mesh aligned with the flow
cfdguy_ is on a distinguished road
Hi everyone, I'm working on TurboGrid to mesh an axial compressor rotor blade. There is a way to align the mesh with the flow, changing the passage inlet and outlet position on tangential direction? I've changed the control angles of inlet and outlet, changing the Outline, but it seems this does not affect the mesh (the mesh is not contained in the Outline, but it stays in its original orientation).
Thanks!
cfdguy_ is offline   Reply With Quote
align flow, passages, turbogrid
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
mesh problem in flow region near thin structure... mytruth7 FLUENT 4 December 15, 2013 22:54
[Other] Surface aligned mesh rpasiok OpenFOAM Meshing & Mesh Conversion 6 January 7, 2008 06:55
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
