[ICEM] Fluid & Solid_Interface Error_Conjugate Heat Transfer
Old   February 14, 2025, 04:07
Default Fluid & Solid_Interface Error_Conjugate Heat Transfer
G. Nithyanandham
Nithyanandham is on a distinguished road
In a conjugate heat transfer (CHT) problem, I'm encountering an issue with the fluid and solid interface during the meshing process in ICEM CFD. In **Figure 1**, both the fluid and solid interfaces are selected, and the mesh appears complete with no gaps. However, when the fluid interface is unchecked, as shown in **Image 2**, the interface should only involve the solid region, but I notice some gaps. Similarly, when the solid interface is unchecked, as shown in **Image 3**, parts of the fluid mesh are missing.
Because of this issue, I’m unable to calculate the surface Nusselt number. However, I am able to get velocity and temperature contours.
Is the meshing process done correctly, or is there something that needs to be fixed to resolve these gaps? Any advice on how to properly set up the interfaces in this case would be appreciated.
Nithyanandham is offline   Reply With Quote
Old   February 14, 2025, 10:02
Gert-Jan
Gert-Jan will become famous soon enough
Is this a 2D geometry that you will use in FLuent?
Gert-Jan is offline   Reply With Quote
Old   February 15, 2025, 01:52
Default Interface Error - 3D Jet Impingement - ICEM CFD
G. Nithyanandham
I'm simulating 3D jet impingement. Separate blocking for the solid and fluid domains has been completed, along with association, block splitting, and O-grid generation. No negative elements are present. While I've associated the interface edges with both domains and attempted to smooth the mesh using "Link Edge," some irregularities remain as shown previous query. Anything I missed!. How to resolve this?
Old   February 17, 2025, 03:40
Gert-Jan
Not sure.
I would check the normals of the surfaces. All planar surfaces should be in the same direction.
Old   February 19, 2025, 07:25
G. Nithyanandham
You are saying about this?. How to change the direction?
Old   February 19, 2025, 11:30
Gert-Jan
If you have an Interface or Boundary that contains several geometrical surfaces, then all elements on these surfaces should be oriented consistently.
You can do this in the "Edit Mesh" Ribbon, one the last icons: "ReOrient Mesh"
If you show the mesh of the surfaces, and the elements are coloured differently, then they are oriented differently. Use the menu to orient them consistently. The direction itself doesn't matter.
Then see of this helps.
icem cfd 19, interface error
Heat transfer porous domain - between solid part and sourounding fluid Janis_K CFX 0 May 18, 2020 06:09
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
