[Sponsors] | |||||
Italo Silva
Rep Power: 2 ![]() |
Hi everyone, I'm new to scripting and working with an RPL file that generates a mesh from coordinates and other information. The problem is that when I run the diagnostics, I get the following message:
Running diagnostics for disconnected_vert in subset "all" 1 unconnected vertex was found. A dialog box then asks if I want to delete it, and when I do, everything seems to work fine. However, if I don’t click "Delete," the entire meshing process stops. I need to eliminate this human intervention, as the whole point of a script is to automate the process. Has anyone encountered this issue or knows how to handle it automatically? |
Bernd Brasas
Rep Power: 0 ![]() |
you can switch off the unconnect verts check. This check was implemented in early CFD times, when every memory byte was needed. To delete unconnected vertices frees a bit memory. However, does this line help ? # Delete disconnected vertices ic_delete_disconnected_vertices ic_uns_diagnostic subset all diag_type disconnected_vert fix_fam FIX_DISCONNECTED_VERT disp_subset uns_diag_0 diag_verb {Unconnected vertices} fams {} busy_off 1 |
Italo Silva
Thanks for sharing your solution! I was able to fix the issue by working on the smoothing process. I intended to solve that unconnected vertex before it showed up, but your answer solved the problem as well. Thanks again! Best regards! Best regards! |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
| injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
| Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
| OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
| Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
