[Other] Using Spaceclaim with simple STL surfaces.
Old   March 4, 2025, 11:54
Default Using Spaceclaim with simple STL surfaces.
A Nonymous
qetuoadg is on a distinguished road
I need to use Spaceclaim at the last stage of CAD generation to make using Ansys meshing in Pyfluent.
So far my workflow is to create a watertight geometry in Blender, then export the STL files and import into Spaceclaim. I have started with a simple channel flow geometry as a test case.
I want to know what is the bare minimum required to start automatic meshing. I have created named selections (for the inlet, outlet, walls), but I am not sure what else. Pyfluent isn't happy with this geometry for some reason, and I think it's because I have only so far imported STL files. Many thanks.
qetuoadg is offline   Reply With Quote
Old   March 4, 2025, 11:55
A Nonymous
I should say that I have previously used SnappyHexMesh, which really only requires STL files as input, and you configure the rest of the workflow in your SHM dict file.
spaceclaim
[DesignModeler] Problem with export to Spaceclaim (Workbench) Ralen ANSYS Meshing & Geometry 0 June 4, 2023 04:29
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 02:56
How to create inlet/outlet/wall STL files from a STL CAD model Gentible Mesh Generation & Pre-Processing 1 June 23, 2015 11:18
[snappyHexMesh] What types of stl files are needed in snappyhexmesh? phandy OpenFOAM Meshing & Mesh Conversion 1 February 19, 2015 06:36
Meshing complex white-light/GOM based STL models jola Main CFD Forum 13 January 30, 2012 02:35
