[ANSYS Meshing] Propeller Geometry Causing Mesh Failures in MRF Setup – Need Help Diagnosing
Old   March 22, 2025, 16:05
Default Propeller Geometry Causing Mesh Failures in MRF Setup – Need Help Diagnosing
James
jimbobmillionaire is on a distinguished road
Hi everyone,
I'm working on a CFD → FEA workflow where I’m trying to simulate aerodynamic loading on a two-bladed propeller using Ansys Fluent. The goal is to extract pressure forces and map them onto the blade in Mechanical for stress analysis.
I’ve modeled a propeller using multiple Clark-Y airfoil sections lofted together in Inventor, then cleaned and repaired it in SpaceClaim. The blade is embedded inside a cylindrical rotating domain, which is then booleaned into a larger static rectangular domain (for MRF). All volumes are properly separated and named.
The problem: I can’t get a successful mesh.
Even after simplification, the mesher either:
- Freezes for 30+ minutes on certain faces
- Crashes or returns sliver face / element errors
- Occasionally finishes but with a failed mesh
I suspect the **geometry of the propeller itself** might be the issue—possibly due to spline complexity or twisted surfaces from the lofted airfoil sections.
I’ve tested:
- Face and Body Sizing on prop
- Patch Independent on domains (most consistent but slow)
- Patch Conforming on domains
- Element sizes from 1–10 mm
- Curvature angle from 20° to 40°
- Separate meshing of static vs rotating domains, as well as isolated prop
I’m using my university's Virtual Lab system so I don’t have direct control over compute resources, but I’ve verified that meshing similar models works fine.
**Model details:**
- Blade length/prop radius: 950 mm
- 6+ Clark-Y sections, slightly twisted
- Rotating domain: 2.0 m long, 1.1 m radius
- Static domain: 5×5×7.5 m box
- Cleaned geometry via SpaceClaim auto repair (some spline faces still remain)
I've uploaded my complete Workbench project as a `.wbpz` file here:
📎 [https://drive.google.com/file/d/1IJq...w?usp=sharing]
I would really appreciate any insight into whether the geometry is too complex or if there's a workaround to get a valid mesh.
Thanks so much in advance.
jimbobmillionaire is offline   Reply With Quote
[ICEM] Complex Geometry for Hex Mesh smoerebroet ANSYS Meshing & Geometry 0 January 9, 2015 15:21
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 14:05
How to automate geometry, mesh and case setup using starccm+ jwillie2000 STAR-CCM+ 3 January 26, 2011 11:13
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
