[ANSYS Meshing] Half 3D Wing CFD Analysis on Ansys Fluent having trouble with meshing
Old   April 17, 2025, 13:50
Post Half 3D Wing CFD Analysis on Ansys Fluent having trouble with meshing
GS
GGexotics is on a distinguished road
Hi guys, I am currently conducting a CFD analysis on a 3D wing in Ansys Fluent. During the DesignModler geometry setup, the enclosure, boolean, and symmetry features worked perfectly; however, when I try to run a mesh on my wing, the system shows the error message: "The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem." Does anyone know how to troubleshoot this issue?
Note: I used a 26mm element size initially with a wing chord of 10.2 inches, lowered down to 16mm, and eventually 10mm, but it all shows the same error message.
Note: I contacted my CAD technician, he told me there's no geometry issue in Solidworks, and I use ANSYS Discovery to check for geometry errors on the wing, and nothing is popping up to indicate there is a geometry issue
GGexotics is offline   Reply With Quote
ansys fluent, cfd analysis, mesh error, troubleshooting
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body onlycfd CFX 4 April 29, 2021 03:02
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
Hydrodynamic analysis of submarine model with ANSYS FLUENT? Sovereignty ANSYS 0 January 20, 2019 18:36
3D Wing analysis with Ansys Fluent Avni FLUENT 0 September 17, 2017 09:09
fluent subsonic wing analysis problem fatihcoban FLUENT 0 August 3, 2016 09:41
