[DesignModeler] Creating fluid volume for combustor
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   April 18, 2025, 16:31
Default Creating fluid volume for combustor
Ali
bluntbody is on a distinguished road
Hello everyone. I'm trying to analyze combustion performance for my graduation project. I already created CAD from SolidWorks. However, I'm having trouble creating a fluid domain for my analysis. I use some techniques like Lofting in solidworks, volume extraction in spaceclaim etc. but mostly i take an error code as "operation would result in non-manifold bodies" .I attach the cad screenshot in there. I will be appreciated for your guidance.
https://imgur.com/a/6fww0vi
bluntbody is offline   Reply With Quote
Old   April 22, 2025, 06:52
Gert-Jan
Gert-Jan will become famous soon enough
In spaceclaim, I would create a large box around your geometry, make a segment and then subtract all objects such that they are an obstruction in the flow. That should work.
Gert-Jan is offline   Reply With Quote
Old   April 30, 2025, 22:20
Ali
Thanks for your reply. However, it should not work because I need to obtain the exact fluid volume of the combustor geometry.
Old   May 1, 2025, 02:38
Gert-Jan
There is no reason for your argument that the exact geometry is not maintained.
If you have an exact representation of your solids and subtract that from a gas/air volume, than the exact burner geometry is in your remaining gas/air volume, not?
Why shouldn't it?
bluntbody likes this.
designmodeler, fluid volume, spaceclaim
Artificial wall error in fluent aiden_1995 Main CFD Forum 0 January 9, 2023 15:06
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 10:11
