[ICEM] ICEM CFD mesh generation is slow
Old   December 14, 2025, 10:36
Default ICEM CFD mesh generation is slow
Kim Hyo Young
okgydud is on a distinguished road
Hi guys
I am trying to understand why ICEM CFD is performing slowly.
My workstation is equipped with an Intel Xeon Silver 4210 CPU.
Generating a mesh takes more than 1 to 2 hours, and sometimes the process even crashes.
okgydud is offline   Reply With Quote
Old   December 15, 2025, 16:32
Gert-Jan
Gert-Jan will become famous soon enough
- It depends on the meshing method you use. Can you elaborate?
- It depends on your geometry. If the geometry is sloppy, then ICEM has a lot of holes to repair. This takes long. The solution is to provide a smooth geometry.
- It also depends on how many elements you have. The more, the longer it takes...
- Did you create Body points. It you don't, then ICEM doesn't understand your geometry.
- Are you sure you havve turned on "Parallel meshing".
Gert-Jan is offline   Reply With Quote
Old   December 16, 2025, 23:10
Kim Hyo Young
Thanks for your answer.
I was using only tetra mesh generation.
I also realized that I had been running it in single-core mode.
After switching to parallel processing, the meshing speed improved significantly.
[ICEM] How to generate an unstructured mesh for a 2 fluid domain rotor in ICEM CFD Hazem24 ANSYS Meshing & Geometry 0 December 21, 2020 07:52
ICEM CFD Part Mesh VS Curve Mesh? Mohammad_Tayseer ANSYS Meshing & Geometry 1 October 1, 2020 22:30
[ANSYS Meshing] Generating Hexa-Core with ICEM CFD Interactive dawdybishop ANSYS Meshing & Geometry 1 October 31, 2017 21:50
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 04:46
[ICEM] ICEM CFD: STL surface mesh to volumetric mesh a.sarami ANSYS Meshing & Geometry 0 August 20, 2013 11:32
