April 1, 2009, 12:29 |
Issues with Cooper Volume Meshing
#1 | |
Hi all, I'm trying mesh the volume shown in the first picture using the Cooper Method. My source mesh is shown in the second picture. When I implement the Cooper scheme, Gambit generates negative volume cells (which can be seen in the mesh slices in Images 3 & 4). I really don't understand how gambit can mess the mesh up before it gets to the portion of the volume where the expansion starts since it is a straight pipe up till that point. I want the boundary layer mesh to maintain its dimensions the entire length of the volume.
I've tried to split this volume into two portions so that I would have one volume with the red face in Image 1 and one with the yellow faces. When I tried this I get the following message: Quote:
Does anyone know what is going on with the Cooper scheme and/or know how to fix it? I am also open to alternative ideas on how to mesh this volume. Thanks in advance |
April 1, 2009, 12:57 |
Maxime Perelli
Rep Power: 41 |
Hi Forrest,
The best way is to plit your volume in several volumes. The first volume should be a pipe till the expansion. Then you may mesh the other volume (not the pipe). Don't try to mesh too fast (direct with BL), because when you split your domain you lost the BL. So try to mesh with cooper the volumes, and then if all is ok, you can apply the BL. For meshing the volume, mesh with quad-pave the smallest cap. Then enforce the cooper scheme, with the right sources (small and big cap). if it's not ok, try to resplit this volume, but it should be ok, it's like a conus. Once this volume is meshed, propagate this mesh along the pipes. But your problem is that your work with virtual volumes, so the splits aren't so simple. Try this way: split edge --> split faces with the vertices produces from the edge splitting --> create the face with the generated edges and split the volume with the face. In real volume, you would have to expand the face to be sure that the face split all the volume (I assume this is a tolerance issue). I was face dto this problem today, and I solved it with this way |
April 1, 2009, 16:13 |
#3 | |
Ok, I was able to split my "pipe" volume into two pieces (the blue and red one in the image). I was able to mesh the straight pipe volume succesfully with the cooper scheme without generating any highly skewed cells or inverted cells. (I meshed each volume separately)
Unfortunately I was so lucky with the expansion part. I think this is because I have a lot of points clustered near one end of the semi-circle so that I can better capture an exit jet in the straight pipe portion. I am correct in assuming that I will have to split this volume up into smaller volumes to mesh it properly? I had a question regarding your suggestion about the BL meshes. You said: Quote:
April 1, 2009, 17:13 |
Maxime Perelli
Rep Power: 41 |
yes you can mesh your volume, then apply the BL and remesh the volume.
Regarding the expansion, I saw on the 2nd picture that you have a small edge on the front surface (which generates a poor surface mesh quality). Try following steps: split the opposite edge, and reproduce the same small edge (but at the opposite) split the face with those 2 vertices. Your surface is now splitted into 2 surfaces (one is a rectangle) Extrude this edge along the y-axis, and split the volume. In other words do the same procedure as here: http://www.cfd-online.com/Forums/ans...on-w-pics.html |
April 3, 2009, 17:46 |
Ok, I split the volume of my entire pipe volume (including the expansion) like you suggested by make a small rectangular volume to deal with the clustering (I also split the expansion volume in half). I am able to generate a mesh with no skewed cells (>0.97) and and no inverted elements with just a paved triangular source face. However everything goes down the drain when I try use a source face with a boundary layer mesh (on the small semi-circle face). Everything works great as it goes through the straight portion of the pipe, but gambit has some real problems when it tries to mesh the region where it goes from a circular pipe to the expansion (highly skewed elements and inverted elements are formed). Is applying the BL mesh to the source face the best way to go about applying the BL mesh, or should I try to attach a BL mesh to the face?
April 4, 2009, 03:11 |
Maxime Perelli
Rep Power: 41 |
If you want to have an cooper mesh on the expansion, Gambit will take the small cap as source and will patch it on the expanded cap.
So I think you will have degenerated cells because of the brutal expansion. If you absoloutely want to deal with hexa you will have to split the volume in small ones along the axis (for a better control of the expansion). Or you can mesh it with tetra-hexcore (tetra outer layer with hexa core) and you may apply a size function on the small cap. As I said you may deal with the BL once all the splits etc are done... (but maybe I'm wrong) |
September 19, 2018, 04:07 |
maybe the solution
Yang Li
Rep Power: 7 |
I also encountered the same problem as you. After a lot of trials, I finally found a solution: in default setting, change the MESH-EXACT_MESH_EVALS to 1. Not sure if it applies to your problem, you can try. But nine years have passed, I guess very few people are still using such old software.
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
