[GAMBIT] Can't refine face mesh enough
Old   April 3, 2009, 13:37
Default Can't refine face mesh enough
Matthew
mbeals is on a distinguished road
I am attempting to model an aircraft probe that is a rather complex shape. I have an image below:
I have manipulated the face meshes to get worst element skewness to around 0.7, but due to the sharp tips (below), I can't improve beyond that. This is with the tips being meshed on a 0.25 spacing. I have a boundary layer attached to the faces of the entire probe, which starts at .5 and grows at 1.4 for 8 layers. When I attempt to volume mesh this (subtracted from a cube), using T-grid, it always fails, telling me to check skewness in areas of small gaps. No amount of refinement seems to get it to work. The only way I have successfully meshed it was when I used stairstep. However that ignores the boundary layer and produces a highly skewed volume mesh. Any tips or tricks on how to approach this would be greatly appreciated.
mbeals is offline   Reply With Quote
Old   April 3, 2009, 13:55
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Merge the 2 faces in front of your geometry, it will delete the diagonal edge which generates the small angle (and produces high skewness).
Do the same at the adjacent side (right side on the picture) with the other diagonal edge.
-mAx- is offline   Reply With Quote
Old   April 3, 2009, 14:48
Matthew
awesome, thanks.
Quick question. Could I merge the other two flat faces with the front one too without losing the shape of the tip?
Old   April 3, 2009, 15:02
-mAx-'s Avatar
Maxime Perelli
Gambit won't allow you to do that, because the edge is needed to describe the shape.
What should be the aim for this? if the diagonals are gone, you are in the case of 90° corner (ideal)
But you can try (save before)
Convergence problem when refine the mesh... TB CFX 37 May 13, 2019 18:50
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[mesh manipulation] TranformPoints gives skewed mesh Possible Bug andersking OpenFOAM Meshing & Mesh Conversion 3 March 25, 2008 21:33
Numerical calculation interFoam never finishes unoder OpenFOAM Running, Solving & CFD 9 October 18, 2005 05:00
how to increase face mesh no.? Shankar FLUENT 4 August 9, 2002 15:48
