[GAMBIT] 3D Boundary Layer Laminar and Turbulent meshing |
July 7, 2009, 05:07 |
Harald Dopper
Hi all
I'm working on a flow around a car with both a laminar and a turbulent boundary layer. I did some wind tunnel tests to get to know where transition is and now I'm making the mesh, using Gambit, for the CFD computations. For the CFD computations I will model the laminar boundary layer as a laminar zone in Fluent. I was wondering if I had to make a separate volume, containing only the laminar boundary layer? Because Gambit can only make zones from volumes. Or is there an other way or program (ICEM or T-grid) which can convert the boundary layers, both laminar and turbulent, made in Gambit into zones? Harald |
July 7, 2009, 06:20 |
Maxime Perelli
Rep Power: 41 |
For the laminar zone, you have to isolate this volume from the others.
If you create a BL, then you won't be able to set this region as laminar. So you need (as you said) to make a separate volume.Then go to Zone panel (the one near the BC panel). Then choose the volume and set it as zone. That's it from the gambit's side
In memory of my friend Hervé: CFD engineer & freerider |
boundary layer specifications for laminar flow | ranjith | CFX | 7 | October 16, 2017 08:09 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 10:24 |
2D Boundary Layer Development in CFX11 | Chris Basciano | CFX | 1 | August 28, 2008 16:15 |
Laminar or tubulent Boundary layer? | Rodrigo Madariaga | FLUENT | 1 | January 23, 2003 20:41 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
