[GAMBIT] Kindly asking help about "unfilted mesh" in Gambit
Old   July 17, 2009, 06:23
Default Kindly asking help about "unfilted mesh" in Gambit
CJ
solefire is on a distinguished road
When I export a mesh file , it warns : At least one geometry entity has no mesh for export . You can use the "Unmeshed" filter in the geometry summarize picker to find the unmeshed entitied.
Then I did use unmeshed picker to check all the volumes, I don't think there is one of them unmeshed. Also it seems ok when i input the mesh in to Fluent. (It runs properly)
Is there any one could give me some guide lines? Thanks a lot!
C.J
solefire is offline   Reply With Quote
Old   July 17, 2009, 06:49
-mAx-'s Avatar
Maxime Perelli
you may apply this filter for volume and also surface.
maybe you defined a standalone surface, which doesn t belong to any volume.
That's why you can run your mesh properly.
Old   July 17, 2009, 08:03
CJ
Thanks MAX. That is probably the problem. I will check it now~
Old   July 17, 2009, 08:04
CJ
I am new user of Fluent , even don't know how to say Thank you in the right place.
Old   May 19, 2020, 13:00
Default Gambit export error
Surya
surya_raj is on a distinguished road
I am new to Gambit software. When I am exporting the geometry, I am getting a warning saying as "At least one geometry entity has no mesh for export," but all the parts of my geometry has a meshing.
Can anybody help me out with this
Thanks in advance
surya_raj is offline   Reply With Quote
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Gambit batch - kill "Startup" box how? Chris Bailey FLUENT 2 February 23, 2005 09:05
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
