[GAMBIT] Meshing two phases
Old   August 31, 2009, 14:20
Default Meshing two phases
Deside
Deside is on a distinguished road
I am working on simulation of a two phase system, one floating on top of the other due to density differences. I want to understand the flow field on the interface of these two fluids which are set in motion by air injection. can you help me on the proper meshing possible for elaborate results.
Deside is offline   Reply With Quote
Old   September 1, 2009, 01:06
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Basically you can define 2 fluid zones.
You have to split your volume into 2 connected subvolumes.
Then you define each subvolume as fluid domain (say fluid1 & fluid2)
In Fluent you will be able to treat the 2 fluid domains separately by defining the right material parameters
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
mesh size, phase, velocity profile
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
