problem importing solidworks file into gambit |
September 15, 2009, 06:41 |
[GAMBIT] problem importing solidworks file into gambit
airakaz
Rep Power: 16 |
as stated, i'm using solidworks 2009 with gambit version 2.2.30..
i already save it in acis format, but when i'm import in gambit, i got this error: "ACIS error 50005, save file is from a later version of ACIS" than, i try save it in parasolid format, but i got different problem: "ERROR: translation requires license features geom- trans" anyone? or i need to use the latest version of gambit?? thanks everyone... Last edited by mzack1104; September 16, 2009 at 12:48. Reason: edit title |
September 16, 2009, 11:20 |
ACIS version.
Simon Pereira
Rep Power: 47 |
Check your acis versions...
It may be that Gambit only supports up to acis 18.0. I don't recall the exact number off the top of my head. your Solidworks 2009 may be outputting ACIS 18.3 or 19 or 20 or somethin in that range (> than what is supported by Gambit import). The solution is to look into Solidworks to see if you can export an older format of ACIS. |
September 16, 2009, 12:44 |
#3 | |
airakaz
Rep Power: 16 |
September 16, 2009, 16:01 |
Output older format from Solidworks 2009.
Simon Pereira
Rep Power: 47 |
Nope, I mean look into Solidworks to see if there are options for what version of ACIS you output. See if Solidworks 2009 has an option to output older formats of ACIS.
If you output an older ACIS format (18.0 or older) from Solidworks 2009, then Gambit will be able to read it. |
September 17, 2009, 11:27 |
#5 | |
airakaz
Rep Power: 16 |
Thanks again! |
Display Modes | |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
Solidworks IGS to Gambit Problem | Mustafa Ayad | FLUENT | 8 | January 18, 2009 12:21 |
Importing Mesh file to Gambit | Sri | FLUENT | 0 | February 28, 2007 10:26 |
importing solidworks2003 file to gambit 1.2 | utku | FLUENT | 3 | June 3, 2004 04:13 |
File Size Exceeded problem in GAMBIT | Prateep Chatterjee | FLUENT | 3 | February 9, 2000 21:31 |
