[GAMBIT] Import vertex data question
Old   September 19, 2009, 10:22
Default [GAMBIT] Import vertex data question
siw
Stuart
siw will become famous soon enough
To import vertex data into Gambot (I'm using version 2.4.6) I see from other topics that the imported txt file just needs to list the x, y and z co-ordinates and for 2D the un-used axes must list zeros.
But does the first vertex have to be at 0.0 0.0 0.0? Because my data is given with respect to an origin that is not located at the first vertex and Gambit says "Error reading number of points per curve and number of curves:
-0.3 0.0 0.0
-0.2752 0.0192 0.0
-0.2566 0.0243 0.0
-0.238 0.0279 0.0
-0.207 0.032 0.0
-0.176 0.0346 0.0
-0.145 0.0362 0.0
-0.114 0.0372 0.0
-0.083 0.0377 0.0
-0.052 0.038 0.0
-0.021 0.038175 0.0
0.28138 0.038175 0.0
0.44438 0.01525 0.0
0.44438 0.0 0.0
I also put in a line above the data with 14 1 to specify the number of points and curves but the same error happened. The Gambit guide says nothing about vertex data format.
This plots fine in Excel so I know there's no errors in the data.
Thanks.
siw is offline   Reply With Quote
Old   September 24, 2009, 01:04
udayrg is on a distinguished road
hi
I TRIED WITH SAME POINTS YOU HAVE DISPLAYED AND WITHOUT A HICCUP GAMBIT PLOTTED THE POINTS.
READ THE *.TXT FILE FOR IMPORT VERTEX OPTION IN GAMBIT
THIS MIGHT HELP
udayrg is offline   Reply With Quote
Import data history Ema CFX 6 June 9, 2009 04:28
Switching forum software. Import question. Peter Main CFD Forum 14 January 23, 2009 06:56
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
vertex post data george Siemens 1 January 6, 2007 14:31
radial turbine data export question ally CFX 0 September 14, 2005 15:10
