[GAMBIT] Difference between real & virtual line, face, & volume?? |
October 4, 2009, 23:54 |
teguh hady
Rep Power: 17 |
Hi...
I've made geometry of turbine in GAMBIT. In my drawing there are virtual and real line. sometime, virtual cannot be converted to real line. What is Difference between real & virtual line, face, & volume?? what is the effect in my simulation in FLUENT?? Thanks teguhtf Last edited by teguhtf; October 5, 2009 at 02:11. |
October 5, 2009, 02:09 |
Maxime Perelli
Rep Power: 41 |
no impact of the simulation and mesh itself.
Just on the construction of your geometry (split-merge etc...). For instance boolean operations work only with real entities Splits are easier with real entities, but not impossible with virtuals.
In memory of my friend Hervé: CFD engineer & freerider |
October 5, 2009, 07:47 |
teguh hady
Rep Power: 17 |
Thanks -mAx-. It works!!!
diference, line, real, virtual |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Parallelizing a UDF | tstorm | Fluent UDF and Scheme Programming | 3 | August 20, 2009 12:31 |
convert virtual volume to a real one | djalil | FLUENT | 0 | January 22, 2009 15:07 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
