[GAMBIT] how controll mesh quality
Old   October 14, 2009, 11:08
Default how controll mesh quality
bob12 is on a distinguished road
hi all
i have generate a mesh with cooper scheme, but the quality is not very good. after some trial i can do a mesh that don't have negative element and no equisize>0.97. the problem that the worst element is about 0.8.
what are the parameters that i must controll?
bob12 is offline   Reply With Quote
Old   October 15, 2009, 02:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Basically you need to control the equisize skew
Go and check the quality by clicking the icon at the bottom right.
Worst element with 0.8 is quite good.
I have no problem with mesh (unstrutured), which max equisize skew is 0.9
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 15, 2009, 06:06
ok.
if i want to better mesh what can i do?
thank you for all max!
Old   October 15, 2009, 06:44
-mAx-'s Avatar
Maxime Perelli
try to understand why are the cells so skewed, and try to correct them with size function, etc...
But as I said 0.8 is good.
Old   October 16, 2009, 14:48
Question reference of meshing
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi All!!!
Is there a reference to say that our meshing is good??
Can you tell me that reference??
Thanks
teguhtf
teguhtf is offline   Reply With Quote
Old   October 19, 2009, 01:51
-mAx-'s Avatar
Maxime Perelli
check gambit help... but it s just theory.
Your self-experience will be helpfull..
From my side, I try to get mesh with max equisize skew about 0.9 (complex geometry with tetra-hexcore elements)
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
mesh quality julie FLUENT 5 July 26, 2004 05:31
