[Gambit] External 3D boundary layer mesh
Old   October 16, 2009, 10:20
Default [Gambit] External 3D boundary layer mesh
Ethan
insaneflyz is on a distinguished road
This is not a new problem in this forum but I have been unable to find any working solution.
I have a 3D model and I need to place an external boundary layer mesh around it. However, Gambit always points the boundary layer into the model or along the face of the model.
Please help here.
Thank you
Ethan
insaneflyz is offline   Reply With Quote
Old   October 19, 2009, 01:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
while choosing surface/edge, if you continue clicking on the same entity you can specify the orientation of the BL.
from gambit-help:
"When you add an edge to the Picked scroll list by means of the right-arrow command button, GAMBIT adds the edge to the Edge column and automatically includes one of its associated faces in the Face column. (The face defines the direction of the boundary layer.) If you add the same edge again to the Picked scroll list, GAMBIT creates a second entry for the edge in the Edge column and includes another of its associated faces in the Face column. When the Face column includes all faces associated with a given edge, GAMBIT removes that edge from the Available column"
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
boundary layer, external, gambit, mesh
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
AMG divergence and boundary layer mesh Justin FLUENT 0 November 4, 2007 17:24
Boundary layer and mesh generation Marcin FLUENT 0 August 29, 2005 16:30
creating a boundary layer mesh SANAT DAS FLUENT 1 August 11, 2005 12:57
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
