October 14, 2009, 01:38 |
help( solid and liquid mixing)
sanaz
Rep Power: 16 |
Hi, I am simulating the liquid-solid flow using FLUENTin in stirred tanks using impeller. My problem is that when I go to the multiphase model, it does not read the solid material and how to build geometry (for soild) in gambit? how to define solid material for gambit. How can I make it reads the solid phase in the multiphase model? Thanking you for any help regarding this problem.
October 14, 2009, 02:04 |
Maxime Perelli
Rep Power: 41 |
do you have to construct your geometry within gambit, or do you have to import a cad file?
In memory of my friend Hervé: CFD engineer & freerider |
October 14, 2009, 02:18 |
sanaz
Rep Power: 16 |
yes. I have to construct my geometry within gambit.
October 14, 2009, 02:22 |
sanaz
Rep Power: 16 |
Yes. I have to construct my geometry within gambit.My problem is more for solid.
October 14, 2009, 02:26 |
Maxime Perelli
Rep Power: 41 |
Do you have the possibilty to construct your geometry with a cad software? Because building an impeller with gambit won't be easy
October 14, 2009, 02:29 |
structure
sanaz
Rep Power: 16 |
October 15, 2009, 10:25 |
Maxime Perelli
Rep Power: 41 |
sounds like ok, take care to model the fluid domain and not the solid one.
Solid particles for multiphase is embeded in Fluent (check user guide), but you don't have to model and mesh them (hopefully...)
help( solid and liquid mixing) | sanaz | Main CFD Forum | 1 | October 21, 2009 01:41 |
solid liquid phase change (melting/solidification) | ernane | CFX | 0 | February 3, 2009 14:24 |
Heat transfer from solid to liquid | Richard | FLUENT | 2 | January 30, 2006 04:10 |
Shacking CAN VOF HEAT LIQUID SOLID | Optixxx | FLUENT | 0 | July 30, 2005 11:42 |
solid suspension in moving liquid | Jason | FLUENT | 4 | October 27, 2003 18:59 |
