Best mesh for heating and ventilation cfd?
Old   December 1, 2009, 07:13
Default Best mesh for heating and ventilation cfd?
kingjewel1 is on a distinguished road
Hi there,
I'm looking to use a structured cartesian mesh for a CFD simulation of a passive scalar in CFX. Can you recommend this type of hex meshing or are tets better?
Best regards
kingjewel1 is offline   Reply With Quote
Old   December 13, 2009, 00:12
Default Depends.
PSYMN's Avatar
Simon Pereira
Hex mesh generally gives better quality, more efficient, more accurate, etc. particularly for certain physics like combustion or when you really want to capture the viscous effects due to high speed flow. But this comes at a price (difficulty to generate for some configurations.)
If your configuration is simple, like a blade row model or a bypass fan duct or something like that. You could probably generate the Structured Hexa mesh very easily, perhaps quicker than a tetra/prism mesh, so the decision is easy.
If it is more complex, like a water jacket in an engine block, or an underhood cooling model, the Hexa blocking might take you such a long time that you would rather just fill it with an nice tetra mesh and take your chances on the slightly reduced fidelity.
But note that multiblock (like ICEM CFD Hexa) is very different from Cartesian mesh. Cartesian mesh is always aligned (XYZ) and probably doesn't fit the geometry very well, which may make it much less accurate than Tetra/Prism (unless the geometry is a box). Mutli-block Hexa can fit the geometry and give you the high quality. It can be structure or unstructured, but that is just referring to how the data in the mesh file is organized (we can covert between the two).
Best regards,
Simon
Old   December 13, 2009, 11:42
Default Bfcart...
PSYMN's Avatar
Simon Pereira
One other thought...
We have a new mesh method called Body Fitted Cartesian. I have not tried it on HVAC yet (Usually use it for Bio-medical or EMAG, but it may be ideal. If this is a model you could share, I could try it out...
We are also working on a new CutCell Cartesian mesher and could use it as a test case for that also.
Simon
beginning cfd and application of it in industrial ventilation mjzs63 Main CFD Forum 0 May 11, 2009 03:18
CFD for ventilation effectiveness calculations? Isabelle Main CFD Forum 0 July 23, 2007 15:20
industrial ventilation + cfd turbman CFX 2 December 17, 2006 07:31
CFD analysis of natural ventilation Martin Murphy Main CFD Forum 1 February 5, 2005 09:02
Heating and Ventilation CFD URGENT Peter Main CFD Forum 8 June 20, 2002 09:42
