[DesignModeler] Need some help with DesignModeler |
January 21, 2013, 14:43 |
Rep Power: 13 |
Hi, I am trying to model a 3-D room with various inlets and outlets. In the end, I would like to be able to see the pathlines of the flow, along with the flow of different types and sizes of particles I inject. Right now I am having trouble completing the 3-D geometry with the inlets/outlets.
So far, I have done the easy part in completing the solid rectangle. Now to add the inlets/outlets is where I'm stuck. All I did was draw a rectangle on 2 different surfaces and I created a surface from the sketch. Is this how I would go about doing this? When I tried to mesh it I couldn't get the mesh to work. I want to have at least one inlet/outlet on each wall and the ceiling. All help is greatly appreciated. Thanks in advanced! |
January 22, 2013, 03:36 |
zhao xin
Rep Power: 16 |
There is an operation in Extrude called 'Imprint Faces'
January 22, 2013, 19:18 |
Rep Power: 13 |
Thanks for the reply, it helped out a lot.
Ok, so I have impinted all of the inlets and outlets that I would like to use. I just want to run this by anyone looking at this to see if what I did make sense and will work. So here is what I have so far: http://imgur.com/ZZnS9eZ. Sorry, for some reason it wouldn't let me insert the picture. I imprinted all of the inlets/outlets and selected "To Next" for Extent Type. I think this extended them into the body. By doing this, does this only cause the rectangles to be on the surface, acting like actual inlet/outlet vents? If not, how can I do this? Last edited by S1m0n1; January 22, 2013 at 19:20. Reason: Give thanks to person who replied |
January 23, 2013, 03:47 |
Imprint only affects the surface, so you're good.
Display Modes | |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
Physical size of geometry in DesignModeler | Michael Rasmussen | CFX | 9 | June 16, 2017 04:27 |
[DesignModeler] find features of Gambit in DesignModeler | code_source | ANSYS Meshing & Geometry | 13 | April 30, 2014 08:33 |
[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench | la7low | ANSYS Meshing & Geometry | 2 | February 21, 2011 16:12 |
How to create a variable-pitch helical sweep in Designmodeler (v11.0) | dgasperi | ANSYS Meshing & Geometry | 0 | August 13, 2009 14:11 |
