[GAMBIT] HELP!I have a problem when starting the unsteady iteration
Old   January 19, 2010, 08:53
Unhappy HELP!I have a problem when starting the unsteady iteration
xuusst
usst139 is on a distinguished road
I have a problem when starting the unsteady iteration in Fluent,and it said——"warning:non-positive volumes exist.
Error:divergence detected in AMG solver ressure correction
Error object)
I guess something wrong with my original grid in Gambit?
hELP ME!THANK YOU!
usst139 is offline   Reply With Quote
Old   January 20, 2010, 01:50
-mAx-'s Avatar
Maxime Perelli
2d or 3d?
if you are working in 2d axi-symetric solver, check out that your domain is in +(xy) plane
if 3d, go back to gambit and examine mesh (icone bottom righ). Choose volume and set the min to 1 and the max to 0.
It will show you negative volume cells
-mAx- is online now   Reply With Quote
Old   January 21, 2010, 01:30
Thumbs up
xuusst
thank you,-mAx-
My condition is in 3D,and i checked the mesh when importing the mesh from Gambit to Fluent,and didn't find negative volume then.
I agree with you that there is sth improper in my mesh,but I've no idea how to improve it,now I 'm trying to use the Boundary Layer or Sizefunction to make a better mesh^
And in your reply,I don't understand the sentence your said that"mesh (icone bottom righ). Choose volume and set the min to 1 and the max to 0. It will show you negative volume cells",would you please explain it more simply?
Thank you again
Old   January 21, 2010, 04:04
-mAx-'s Avatar
Maxime Perelli
http://www.ent.ohiou.edu/~juwt/HTMLS.../tg01.htm#1447
choose Volume type (instead of skewness), then set to lower level to -1 and the upper to 0
Then update
After importing your mesh in fluent, do a Checkmesh and pay attention to warning regarding negative volume
conditions for unsteady problems dvdromnu OpenFOAM Running, Solving & CFD 5 November 9, 2009 02:15
Force report every iteration in unsteady flow calculation Friso Landstra FLUENT 0 October 23, 2009 07:13
Problem in Reporting Unsteady Particle Fates Nelson FLUENT 0 August 23, 2006 20:24
steady and unsteady Euler eq problem AO Main CFD Forum 3 January 27, 2004 16:29
Question concerning about unsteady problem.... ghlee Main CFD Forum 6 October 2, 1998 05:36
