[ICEM] meshing a long pipe
Old   January 30, 2010, 02:27
Question meshing a long pipe
feizaghaee's Avatar
moein
feizaghaee is on a distinguished road
Send a message via Yahoo to feizaghaee
hi i'm going to mesh a long pipe. it's 180 meter with 1.5 meter diameter. this pipe has 90 degree curve after 30 m from inlet whit curve radius of 15 meter. i want to generate a prism mesh with triangular base that every cell has 1 meter length along the pipe. how can i do that.
look forward to your answer.
kind regards.
feizaghaee is offline   Reply With Quote
Old   January 30, 2010, 07:50
feizaghaee's Avatar
moein
nobody knows?
Old   January 30, 2010, 12:32
kakhtar is on a distinguished road
Did you follow tuturial No1 of ICEM
kakhtar is offline   Reply With Quote
Old   January 30, 2010, 14:29
feizaghaee's Avatar
moein
That tutorial is 2D. My project is 3D and in that tutorial mesh is tetrahedral. That means its pyramid but I want to generate perism mesh.
Old   February 2, 2010, 04:28
gajemon is on a distinguished road
post a picture of your long pipe
gajemon is offline   Reply With Quote
Old   February 3, 2010, 10:58
Default options...
PSYMN's Avatar
Simon Pereira
Are you looking for a swept mesh or a tetra prism mesh?
If it is tetra/prism, I think that a 1 meter long cell with a 1.5 meter diameter pipe is too coarse. You won't get enough curvature capture (assuming the prism is equilateral).
I would suggest a sweep method.
Mesh the end of the pipe (quad dominant, but with inflation (2D-BLayer)) and then use the option to extrude the mesh along the curve of the pipe. You will be able to have a decent cross section mesh, but have high aspect ratio elements so you can easily achieve your 1 meter length elements, but with good fit in your 1.5 meter diameter pipe.
ICEM CFD Hexa would also be a very good choice for this geometry. you could block it quickly and use an OGrid to very precisely control the boundary layer.
Old   February 4, 2010, 14:54
feizaghaee's Avatar
moein
i have use Hexa mesh and blocking but i think if i use tetra mesh i would obtain better result. i want to use a mesh in shape of triangular that extruded normaly.
Old   February 5, 2010, 00:23
PSYMN's Avatar
Simon Pereira
Since your pipe bends, a simple normal sweep won't work, but you could run a curve along the center of the pipe (or perhaps a seam along the side or inner surface of the bend would work...)
Then Extrude the mesh along the curve.
Simon
Old   February 5, 2010, 09:15
longbow is on a distinguished road
Why do you think tetra mesh is better in your situation? On the contrary, Hexa mesh is well-known to produce better results with less number of nodes/elements in wall-bounded flow.
longbow is offline   Reply With Quote
Old   February 6, 2010, 05:43
feizaghaee's Avatar
moein
thanks a lot
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Problem with meshing long, thin faces in CFX Martin CFX 3 January 8, 2009 20:51
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 08:29
Meshing divergent nozzle entry of a long pipe Aly FLUENT 1 September 25, 2005 17:07
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
