[ICEM] Sweep Mesh - All Quad Free Surface
Old   February 26, 2010, 05:42
Unhappy Sweep Mesh - All Quad Free Surface
Chester
ChesterP is on a distinguished road
Hi all,
I used the sweep method to make a full quad mesh of the simple geometry in attachement. This geometry was created with revolve, boolean and slice operations. Apparentrly ICEM's error is about too big aspect ratio and thus introduces thets elements. But why is that? Because of symmetry it shouldn't be a big deal.
ChesterP is offline   Reply With Quote
Old   February 28, 2010, 00:09
Default Not sure...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I sometimes have better luck if I manually select source faces for a sweep...
But just looking at this, i can't tell what the problem is.
I will send you a separate note with my email address in case you are interested in sending the model for testing...
Anyone else out there have any ideas?
PSYMN is offline   Reply With Quote
Default Hmm?
PSYMN's Avatar
Simon Pereira
Old   February 28, 2010, 10:04
Thumbs up Problem Solved
Chester
Thank you for your interest and your response Simon.
I did what you just said, I manually selected the source and target and it did the trick .
Just for informations, my geometry was done in DesignModeler and cut with a plane of symmetry. Maybe that the model wasn't "clean" enough for the automatic sweep.
Another question : How do I mention that the problem is solved and that the topic can be closed?
Chester
Old   February 28, 2010, 18:53
PSYMN's Avatar
Simon Pereira
I am glad that worked.
I don't know of a way to officially close a thread. Just stop writing on this thread and that will be that.
As for this issue of needing to select the source some times, better automatic source detection is a primary focus of development for the next release.
Simon
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
virtual geometry richard FLUENT 4 January 7, 2009 05:16
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
moving mesh and free surface mark stocksmeyer Siemens 1 July 13, 2001 04:19
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
