[DesignModeler] Creating an external shell
Old   August 4, 2013, 12:47
Default Creating an external shell
Argyrios Stouras
argysto1989 is on a distinguished road
Hello guys,
I have an .igs model of a vertical axis wind turbine and I want to split each blade in order to create an external shell covering an internal core. In Ansys DM is inserted as a solid body and I had an idea to create a surface from one of the finishing faces of each blade (or a line from the edges) create an inward offset line and extend it to the other side to create an internal volume and therefore a body in an other body. The problem is that offset command doesn't allow to select any kind of generated lines from the faces. Should I go manually and create a rough polyline out of the face and go with it or there is an other way in order to have better, automated and more refined results?
Sorry for any kind of bad terminology but I now started to use Ansys.
argysto1989 is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[ICEM] Error in creating prism layers on an external flow geometry zkittur ANSYS Meshing & Geometry 2 June 5, 2017 14:47
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 20:16
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
