Meshing a cylindrical volume
Old   March 18, 2010, 15:19
Default Meshing a cylindrical volume
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Hi
I want to mesh a 3d pipe. How can I do that?
What I tried was: I meshed one face (275 cells) and tried to sweep that face along the axis of the pipe to form the volume. But the mesh density is v high. Gambit takes a default value of 1 in the axial direction. How can I control the axial density of the mesh?
I am new to Gambit. Please help.
Geometry:
Dia: 50 mm
Length: 12.7 m
Approx nodes reqd: 38000.
pranab_jha is offline   Reply With Quote
Old   March 18, 2010, 23:03
pranab_jha's Avatar
Pranab N Jha
Or.. I should put the question like this...
How can I mesh a 3d pipe in Gambit using hex elements?
Old   March 19, 2010, 00:55
-mAx-'s Avatar
Maxime Perelli
Build first the geometry.
Then deal with the mesh.
Once your pipe is build, mesh one cap with quad-pave, and then mesh the volume with the desired element size.
Old   March 19, 2010, 01:56
pranab_jha's Avatar
Pranab N Jha
I did mesh one cap with quad-pave. What option do I choose to control the element size. Is 'cooper' the best option and do I specify the interval count/size appropriately in the axial direction?
Old   March 19, 2010, 02:54
-mAx-'s Avatar
Maxime Perelli
Yes Cooper is the best option (if your volume enables it).
If the cap is meshed, (and you are using Cooper), then the surface mesh for caps are fixed. The "mesh-freedom's degree" remaining is the axial one, so giving the element size for the volume mesh, will be the element size for the axial direction.
Else you can mesh one edge in axial direction, and it will govern the volume mesh densiy (you can try to give a very fine element size for the volume mesh, but as the axial edge is already meshed, this volume element size will be ignored, since you don't enable the delete lowe mesh option)
Old   March 20, 2010, 10:00
pranab_jha's Avatar
Pranab N Jha
Thanks Max... that was really helpful
Old   March 22, 2010, 17:13
pranab_jha's Avatar
Pranab N Jha
I have another problem now. I want to split the inlet of my mesh into two equal parts-upper and lower for two different fluid inlets. How can I do that?
I created a semi-circular face first and then swept it to make myself a "semi-cylinder". Then I mirrored it to get myself two semi-cylindrical geometries with mesh. But the problem is that the two new faces generated due to this (interface between the two semi-cylinders) is taken as a wall when I export the mesh to fluent. I only want two inlets and one outlet to allow mixing of the fluids.
Thanks,
Pranab
Old   March 23, 2010, 00:46
-mAx-'s Avatar
Maxime Perelli
your "interfaces" seem to be not connected.
You can connect them in gambit (Surface/Connect)
Old   March 23, 2010, 05:07
Default Similar Problem
Jon
Sidewinder is on a distinguished road
post removed!
Sidewinder is offline   Reply With Quote
Old   March 23, 2010, 14:58
pranab_jha's Avatar
Pranab N Jha
I did get my geometry and mesh right (finally). But I used very basic method to do that.
-I created two semi-circular faces (like a circle) at both ends of the pipe.
-I made faces out of the pair of upper and lower circles.
-I joined the two faces to make the pipe volume. Then I specified the inlet conditions for the two fluids at the two inlet faces.
But I would like to know how I can mirror a half cylinder to form two cylinders (described in my earlier post) and neglect the interface as I do not need it. I will give Max's suggestion a try and see.
Old   March 24, 2010, 00:55
-mAx-'s Avatar
Maxime Perelli
you can copy your volume, enables reflect option and give the right direction's vector. Also enable copy mesh unlinked option. Depending on your coordinate system, you may have to aligne your reflected volume for "glueing" it with the original one.
Then connect the interfaces each other.
Watch out sometimes, the connect operation delete the volume mesh, and you will have to remesh it
Old   March 24, 2010, 05:56
Jon
post removed!
Old   March 24, 2010, 06:10
-mAx-'s Avatar
Maxime Perelli
post a picture, or mail me your geometry
Old   March 24, 2010, 08:17
Jon
post removed!
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
