[Other] [DM] Meshing with Design Modeler
Old   May 5, 2010, 11:38
Default [DM] Meshing with Design Modeler
Jon
TxoniMoni is on a distinguished road
Hi, I'm trying to lear Fluent, so I've started using Design Modeler for meshing, and need to know how to put a surface inside a Fluid. I want to put a boundary condition inside de fluid (I need to put a velocity condition to simulate a fan in a garage).
Please, could someone help me?
TxoniMoni is offline   Reply With Quote
Old   May 9, 2010, 16:01
Default Please help
Jon
Please, can anyone tell me how to put a boundary condition in a surface inside a volumen?
Old   May 20, 2010, 14:35
Default Named Selections...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Do you mean you are representing your fan with a zero thickness (baffle) surface within your solid region?
You create all bocos with a named selection. right click on the surface and choose the named selection option. Name it what ever you want and then when you generate the mesh, that mesh will be in the component with a name that you can a select for bocos in Fluent.
However, if you are using older versions, you may have trouble meshing a baffle in ANSYS Meshing (DM is the geometry tool). Make sure you have 12.1, which can handle the mixed dimension parts. Alternatively, you could create a solid for the fan. It can be thin (make it one element thick), but not zero thickness. Then select the faces to create named selections for the special boco...
PSYMN is offline   Reply With Quote
boundary condition, designmodeler, fluent 12.0, surfaces
Workbech design modeler geometry Faruk CFX 6 October 31, 2010 08:44
Modeling Terrain in Design Modeler Will C ANSYS 0 February 26, 2010 18:13
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
CFX design modeler Merkur CFX 0 June 5, 2006 10:44
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
