[ANSYS Meshing] Structured grid over a 3D triangular prism
Old   April 18, 2016, 18:41
Default Structured grid over a 3D triangular prism
Bleep Skrp
BleepBlorp is on a distinguished road
I am meshing a 3D triangular prism, or a wedge, to study the hydraulic jump formed by using the volume of fluids (VOF) method. In order to prescribe flow with a velocity, I have to assign a volume fraction of 1 to the cells that hold water. In order to do this, I need a structured grid at least to the top of the wedge.
I'm attaching a few screenshots of what I have so far. I divided the wedge into 4 regions and attempted to use the mapped face meshing procedure. This seemed to work on the outer surfaces of the wedge and the enclosure, but when I take a cross section, the grid is unstructured.
Does anyone have a suggestion on how I can extrude the mesh, or maybe how to cast a structured grid up to the top of the wedge?
BleepBlorp is offline   Reply With Quote
Old   April 15, 2021, 10:09
Mauro Killary
maurokillary13 is on a distinguished road
hi currently i have the same issue, i must mesh a triangular prism thus to simulate a incled jet impingement, i use ansys mesh for that, how you've resolved this issue?
maurokillary13 is offline   Reply With Quote
Old   April 21, 2021, 08:32
kjetil is on a distinguished road
In Spaceclaim you split the body by the top surface of the wedge, then use Share topology, and then sweep the bottom part to get a structured mesh. You might get missing inflation just around the top edge, but it probably won't be a big problem if the top wedge surface has a fine resolution.
kjetil is offline   Reply With Quote
Prism mesh from structured block? Iligusk Pointwise & Gridgen 1 June 1, 2014 17:27
Convert 2d, diagonalized, unstructured grid to structured -- CGNS jgrisham Main CFD Forum 1 May 16, 2014 18:26
Simple structured grid RNE Main CFD Forum 2 September 24, 2008 12:50
matrix solver about block structured grid young min, Sohn Main CFD Forum 1 July 11, 2000 19:35
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
