[GAMBIT] Meshing airfoil using .dat file problem |
November 13, 2009, 14:58 |
liam cregg
Rep Power: 16 |
I am using the cornell tutorial (amazing thing) to mesh an airfoil. I have been through the tutorial using the airfoil .dat file provided and had no problems. However when trying to mesh an airfoil that I wish to investigate, I seem to run into some problems. When importing the file only the vertices seem to appear, however with the provided airfoil the faces appear to, this means that when it comes time to seperate the airfoil from circ1, I cannot select the airfoil to do so, and I cannot split the airfoil surfaces later on in the tutorial. please find a .txt version of the airfoil .dat file i wish to investigate. your help is much appreciated Liam |
November 13, 2009, 18:29 |
teguh hady
Rep Power: 17 |
Hi creggie,
Your number of vertex is wrong (Your number is 87 & the correct is 97). Your number of matrix is wrong (Your matrix is 2 & the correct is 1). You cannot divide your matrix become two. because number of your vertex is odd. hope it helps teguhtf
Now Or Never!!! |
November 14, 2009, 08:32 |
liam cregg
Rep Power: 16 |
Fantastic, worked perfectly. When meshing the circ1 part of the geometry I now recieve the error "each boundary must have an even number of intervals". In the tutorial he uses an odd number of intervals on EF, as do I. Sorry for these amatuer problems
November 14, 2009, 09:35 |
teguh hady
Rep Power: 17 |
Number of matrix show number of edge.
Now Or Never!!! |
November 14, 2009, 09:56 |
liam cregg
Rep Power: 16 |
sorry im not sure I understand. I have meshed the airfoil, I am now attempting to mesh the face that connects the circular edge to the airfoil. I have meshed each edge with the same amount of points as the airfoil top and bottom. I still however, recieve the same error as above
November 14, 2009, 10:15 |
teguh hady
Rep Power: 17 |
You should check the value of element and node of your foil and your circular. By using option summarize. Btw, what is number of edge of airfoil??
Now Or Never!!! |
November 14, 2009, 10:23 |
liam cregg
Rep Power: 16 |
I have split the airfoil into 4 edges, as the tutorial suggests, at x=0.3*c. The tutorial made me summarize the mesh edges in order to mesh the circular edge with the correct number of intervals. The top part of the airfoil contains 40 elements from the leading edge to 0.3*c, and 36 elements from 0.3*c to the trailing edge. Thus the top half of the circular edge was meshed with 40+36=76 elements. Using the same technique the bottom half of the airfoil, and thus the bottom of the circular edge was meshed with 75 elements. This is where I assume the error is occuring (the bottom of the airfoil) but this error would be apparent in the tutorial as well, it cleary hasn't occured there though.
November 14, 2009, 10:31 |
teguh hady
Rep Power: 17 |
Number of element in upper and lower edge must same. upper has 76, so does lower. I think there much error of the tutorial. Try others!! chek this tutorial. I think its good for you!! I've run this tutorial and it works well.
http://web.missouri.edu/~solbrekkeng...is_logsdon.pdf hope it helps teguhtf
Now Or Never!!! |
November 14, 2009, 11:24 |
#9 |
liam cregg
Rep Power: 16 |
Tried the tutorial you sent, it's great. However I still have the same problem. When trying to mesh the circular area, I run into problems. However, I can now mesh if i use a pave type, it does however come out extremely skewed. Any suggestions (your help has been great so far). I have also had problems in the subtracting the airfoil from the circular area part, not sure if that affects the meshing of the circular area (ACIS error 8032- inconsistent edge face relationship)
November 14, 2009, 12:22 |
#10 |
teguh hady
Rep Power: 17 |
pave is unstructured mesh. It has flexible usage. But most of airfoil use map or sub map mesh. Quality of mesh will take effect of your simulation.
Read thesis carefully, please!! It will spend much time!! That is the only way.
Now Or Never!!! |
June 27, 2010, 19:24 |
Airfoil in vertical motion
#11 |
SOhail
Rep Power: 15 |
I am trying to run simulation (2D) for 3 bladed NACA 0012 airfoil in vertical motion with respect to central axis using gambit and fluent. I know how to create mesh for single airfoil and run simulation on it, but i don't know how to create mesh for airfoil and to rotate it in fluent. I would be glad if anyone could help me out. Here is a youtube video of what i actually want to do. Please help me out guys, its part of my thesis. http://www.youtube.com/watch?v=1eyEtzdHDEE Regards. |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
Problem with Boundary Conditions using a journal file | T.S. | FLUENT | 3 | July 27, 2009 08:31 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
