[ANSYS Meshing] Trouble with convergence
Like Tree1Likes
  • 1 Post By bluebase
Old   August 25, 2014, 09:39
Default Trouble with convergence
United Kingdom
Andreas2014 is on a distinguished road
Hi all,
I am having trouble with converging one of my 2D simulations.
I have attached an image of the geometry and my mesh.
The mesh is very good quality >0.7 and min angle > 18 degrees.
However, when I run it for simple laminar flow, there appears to be a large pressure building up at the corner (see image 'Close Up') and this prevents the system from converging.
Does anyone have any meshing tips on how to improve this mesh so that simulation converges?
Thanks,
Andreas
Andreas2014 is offline   Reply With Quote
Old   August 25, 2014, 11:50
Sebastian Engel
bluebase will become famous soon enough
Hi Andreas,
i would suggest to try to match the element sizes of adjecent blocks. The expansion ratio could be too high.
Have look at the corner at the smallest element in screen 4. On top of the left block, elements seem to be more than 6 times as big as adjacent elements. In sense of numerics, that's a problem. Often it's recommended to maintain an expansion ratio of 1.2 or smaller.
With regards,
Sebastian
rgd likes this.
bluebase is offline   Reply With Quote
Old   August 25, 2014, 12:21
Default Blocking is not good
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Try some better blocking
Far is offline   Reply With Quote
Old   August 27, 2014, 11:45
United Kingdom
Hi Bluebase and Far,
Thank you very much for your tips. I will give it another shot.
Regards,
Andreas
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
NACA 0012 Convergence trouble mecarlg FLUENT 6 September 3, 2009 19:31
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 11:22
