September 6, 2010, 04:45 |
mesh generation from .vol file
Martin
hallo,
i am relatively new to CFD and meshing... By now I am going through the User's Guide and practicing all day I also installed the programs NetGen and Engrid. With both of them i tried to open a .vol file, which made them crash the .vol is a seal's vibrissae (beard hair), which has been scanned by a scientific machine/computer. It consists of many .tif files, which in sum create the .vol file after merging. I have no idea how to open or mesh it for some flow calculation Could someone please help me? Thank you very much in forecast. Greetings RugbyGandalf |
January 8, 2011, 17:22 |
STL or VRML
Simon Pereira
Rep Power: 47 |
Look for a way to convert that vol file into an STL or VRML file. Often the scanner software will be able to output in these formats (better than conversion). Once you have one of those more standard faceted formats, you will find that a lot of softwares support those formats (including ICEM CFD).
What sort of analysis is this anyway? Sounds interesting. |
January 9, 2011, 11:48 |
Martin
Dear Simon,
thank you very much for your answer. I do only have the files, but no access to the scanner any more. The aim is to analyse the absence of vortexes behind this obstacle while having a fluid flow around this seal's vibrissae caused by it's unique geometry. I maybe found a solution to open those files - it is a program named VolView - published by KitWare - but at the moment i am stressed a lot with learning to pass my exams, so i did not try any more. Greetingz Rugby |
January 10, 2011, 11:54 |
Simon Pereira
Rep Power: 47 |
Interesting study...
Hopefully Volview has an option to output as STL or DXF or something like that. At least with ICEM CFD, you only have to get it as a faceted geometry and don't need a full bspline conversion... Good luck with your exams. Simon |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
