December 2, 2015, 04:32 |
Crazy Surface Mesh
Philipp
Rep Power: 26 |
Hi all,
I have a problem with a part of my geometry that is imported from CAD. I cutted the geometry in different bodies, one of them looks like a cylinder. For some reason, meshing doesn't recognize it as "sweepable", but that doesn't matter here, although this is suspicious and might be a hint to the solution. Anyway, the surface mesh of that body looks horrible and I have no idea how to get it better. Here, have a look. bad_mesh_1.png bad_mesh_2.png Do you have any idea what could be the reason for this? This is "patch conforming", but I need it because I want to use pre-inflation. If I set it t "patch independent" the mesh looks fine. I do not need to get it sweepable, because I want to have different edge resolutions on both sides.
The skeleton ran out of shampoo in the shower. |
December 2, 2015, 05:15 |
Philipp
Rep Power: 26 |
Ok, if I switch off "advanced sizing function" the mesh looks fine. But I need it at other parts...
Any other setting (on: fixed, on:curvature,...) leads to the bad mesh.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
