Input leaks. 20 free element edges found.HELP Meshing Hypermesh
Old   October 18, 2010, 12:49
Default Input leaks. 20 free element edges found.HELP Meshing Hypermesh
Pankaj
panky is on a distinguished road
Iam trying to mesh a heat exchanger pipe with inside cylinder dia9.5mm , length 1200mm and outside cylinder dia 28.5mm and length 1300mm. 2d mesh is fine but while using 3d tetra mesh with cfd mesh its giving the above mentioned problem. The parameters for cfd mesh im using are
Total BL thckness-3mm
First layer thckness-.5mm
growth rate-1.
Kindly suggest.
panky is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Input leaks. 20 free element edges found.HELP Meshing Hypermesh panky Main CFD Forum 0 October 18, 2010 10:33
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 11:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 11:56
Meshing Ring Element Jalen ANSYS Meshing & Geometry 2 October 20, 2009 09:21
