November 1, 2010, 13:24 |
How to model fluid flow pass over fin
ekkapong
Rep Power: 15 |
Dear All
Could somebody give me your suggestion about simulation heat transfer flow pass over the fin by using ANSYS Fluid Flow(Fluent) (I'd like to see the outlet pressure drop, heat transfer of the fin). I already made fin but I have no Idea how to model fluid flow which pass over the fin(I use Ansys flow DesignModeler ), how to set the inlet condition on the part. I pretty new about Ansys so if you guys have the tutorial could you give me about this ?? sincerely your nuenao |
November 2, 2010, 14:56 |
Simon Pereira
Rep Power: 47 |
You need to create an enclosure around the fin that the mesher can fill with mesh to represent the fluid...
If you put both bodies (the fin and the enclosure) into the same part, you will have a multibody part that will mesh with conformal nodes... Then just run tetra prism on it (prism on the fluids side, but maybe also on the solid side)... I recall some packaged demos about this (a heat sink with a fan in a pc tower), but I just did a quick search and didn't find them. I am sure I have it on a CD somewhere but I am mid-move and have not unpacked my office yet. You may find the "killer demo" on the customer portal. Best regards, Simon |
November 3, 2010, 01:19 |
ekkapong
Rep Power: 15 |
Thank you PSYMN, I will try to do it.
November 3, 2010, 22:29 |
ekkapong
Rep Power: 15 |
Dear PSYMN
I try to find out the "killer demo" on the customer portal as you advise me But I don't get it yet. could you help me to find it? Best regards, nuengao |
Help: apply B.C. in my granular flow model ? | Derek Jing | FLUENT | 1 | January 8, 2020 21:38 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
SLUG flow with Two fluid model and VOF | MIJAIL | Main CFD Forum | 2 | February 21, 2008 10:45 |
