Ansys mesh import problem
Old   December 12, 2010, 16:59
Default Ansys mesh import problem
Bla Blubb
sys999 is on a distinguished road
I'm trying to do a modal analysis in Ansys. Here is my problem:
I've made a mesh with Icem and imported it to Ansys Workbench with the FE Modeler. I've connected it to my Modal Analysis System.
When I'm trying to apply supports in Mechanical I can't select the different faces of the model because the programm smoothes it somehow. I can only select the whole body. So I can't apply the support where I want to.
Thx
sys999 is offline   Reply With Quote
Old   December 12, 2010, 17:39
Default sounds like a non-cfd problem
W.N. Anderson
Will Anderson is on a distinguished road
this is a cfd forum, so don't be surprised if support for fem is scarce.
good luck!
Will Anderson is offline   Reply With Quote
Old   December 12, 2010, 18:12
sac
sac is on a distinguished road
When you import the mesh via femodeler it puts a "skin" on the mesh.
When in FEModeler you have some control over how this "skin" is created.
Either you can change the cutting angle to pick off surfaces or you can create the surfaces yourself using the picking tool.
I believe the FEModeler help has a section on doing this.
sac is offline   Reply With Quote
Old   December 13, 2010, 11:14
Bla Blubb
I did it. Thanks for your help...
Old   January 4, 2011, 11:54
arif.iut.09 is on a distinguished road
hay i am also doing a modal analysis can u help me with that..im using ansys 11.im new to this.how to do the meshing can u help. how do i knw what element type i should select
arif.iut.09 is offline   Reply With Quote
ANSYS Workbench mesh crashes (ANSYSWBU.exe problem) kondan ANSYS 76 February 22, 2024 02:27
Import ANSYS CFX Mesh to Fluent Noureddine FLUENT 6 February 11, 2009 12:33
Problem on mesh import to Ansys CFX 10.0 Stephen Lau CFX 1 April 18, 2007 03:02
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
