March 24, 2011, 10:47 |
Grid size
Mohan
Rep Power: 15 |
Forgive the noob question, but after searching and searching I've been unable to find the answer to the following: How do I view the number of cells within Gambit? (I know how this is done in Fluent) How do I view the average cell size within Gambit? Thank you |
March 29, 2011, 02:06 |
Maxime Perelli
Rep Power: 41 |
go to examine mesh (2d or 3d) , select range and update... (don't specify the lower and upper limit for skewness >> let 0 and 1, it will select all your mesh and therefore you will see how may cells you have)
what do you mean with average cell size?
In memory of my friend Hervé: CFD engineer & freerider |
March 29, 2011, 10:04 |
Mohan
Rep Power: 15 |
Thanks Max!
By grid size I mean the area. Mine is a 2D grid. Perhaps there is a way of finding the total area and then I could manually divide that by the number of cells to get the mean "size" ? |
March 30, 2011, 01:08 |
Maxime Perelli
Rep Power: 41 |
you can check the area of your domain, by selecting summarize Faces: Gambit will give you some informations (Area included).
March 30, 2011, 11:41 |
Mohan
Rep Power: 15 |
Excellent! Now I can continue with my work .
thanks max. |
reducing grid size | Marjon van Ginneken | FLOW-3D | 4 | January 12, 2009 09:18 |
grid size | jay | Siemens | 6 | September 5, 2008 05:00 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
increasing grid size | kcg | Siemens | 5 | April 8, 2007 18:26 |
Grid size and combustion simulation | versi | Main CFD Forum | 4 | February 16, 2004 06:42 |
