January 13, 2011, 20:38 |
Flow inside the pipe
Saima
Rep Power: 16 |
I am simulating pipe flow. I have made a solid cylinder in DM but now how can i define interior as a fluid? or wat could be the possible way? Regards, Saima |
January 14, 2011, 10:55 |
Details of Body and/or Named Selections...
Simon Pereira
Rep Power: 47 |
In DM, use the body selection tool (Green Cube in the top row of icons) and select the body in the screen or tree. At the bottom of the details panel (bottom left) there is a pull down to change it from Solid (default) to Fluid...
Solid-Fluid.jpg But this doesn't really matter for most cases... The important thing is to put your Body into named selections which will appear as cell zones you can select in your solver. This movie should explain it better. http://www.youtube.com/watch?v=-6Z2v8geroQ |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 04:04 |
flow in pipe with momentum and energy source | Atit Koonsrisuk | CFX | 3 | March 29, 2005 16:58 |
