[DesignModeler] create edge from points
Old   January 31, 2011, 10:58
Default create edge from points
fatma
code_source is on a distinguished road
how to create an edge from three points on DM?
On Gambit:
edge create center "c1" major "c2" onedge "c3" start 0 end 360 ellipse
Thank you for your help
code_source is offline   Reply With Quote
Old   January 31, 2011, 18:25
Ali
Ali_M is on a distinguished road
I'm fairly new to DesignModeler, but from what I understand you can insert the points manually and then use the 'Line From Points' option and create a line between them.
Ali_M is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
