[DesignModeler] split
Like Tree1Likes
  • 1 Post By jumaah
Old   February 3, 2011, 09:12
Default split
fatma
code_source is on a distinguished road
Hello
I work with DesignModeler for a short time and a look for "split" feature. Where can i find it?
Thank you in advance
(i want to split a face by another face)
code_source is offline   Reply With Quote
Old   April 29, 2011, 16:26
jpo
jpo is on a distinguished road
excellent question, I am trying to do the same
jpo is offline   Reply With Quote
Old   May 12, 2011, 08:05
zhao xin
zxin is on a distinguished road
You can try a command 'slice' .
zxin is offline   Reply With Quote
Old   May 12, 2011, 09:31
jpo
slice how?
Old   May 13, 2011, 04:26
sac
sac is on a distinguished road
This is all in the documentation - which should be the first place you look for an answer.
First go tools -> Freeze to freeze your bodies
Then go to the create -> Slice menu.
Try using slice by surface.
sac is offline   Reply With Quote
Old   May 13, 2011, 07:33
jpo
Thank you for your reply
I looked in the help many times, don't understand anything
How does one create a standalone face? I need it as a slicing tool
Old   August 4, 2016, 07:47
Default Split Volume
saeed2294 is on a distinguished road
Hello.
I want to model PCM by fluent so i need to create multi zones. i want to model my project by Ansys workbench not by Gambit.my question is how workbench can split volumes as like as Gambit,(i mean Design modeler)?
as you know Gambit have split volume but i cant find it in Ansys workbench.
Thank you.
saeed2294 is offline   Reply With Quote
Old   August 10, 2016, 02:31
Kapi is on a distinguished road
slice your volume,
go to help section look it up and do some tutorials
Kapi is offline   Reply With Quote
Old   August 15, 2016, 03:03
Hi.thanks for your answer..shall i ask you to explain more?
it is about two weeks i work on it and i cant find any solution.
Old   August 15, 2016, 19:00
Default split surface and slice body
Omar jumaah
jumaah is on a distinguished road
to split the surface of geometry
1- select the surface then create a new plane
2- create a line that demarcate your division, on generated plane
3- tools / face split
target face : select the required face
tool geometry : points on the line
4 - generate
to slice body into parts by sketch
1- create sketch in a new plane
2- extrude that sketch by choosing : slice material
or you can slice the body into parts using planes
I hope this will help
jumaah
saeed2294 likes this.
jumaah is offline   Reply With Quote
Old   August 17, 2016, 02:24
Hello.
Old   July 13, 2022, 05:58
jamieoliver is on a distinguished road
Thanks for posting this question. I have the same issue as you. I try the command "slice" but it doesn't work. flixdle
jamieoliver is offline   Reply With Quote
[GAMBIT] Split volume - when reflecting volume, the copy blows up enfinity ANSYS Meshing & Geometry 7 May 3, 2011 02:13
[ICEM] Split O grid BrolY ANSYS Meshing & Geometry 1 July 2, 2010 09:23
how to split hex mesh in icem with desired height? adam2008 ANSYS Meshing & Geometry 3 August 27, 2009 14:59
split functioin in CCM+ Peter Specht Siemens 1 March 5, 2008 08:14
