February 4, 2011, 07:23 |
Static Ansys (Ansys)
Mohamed
Rep Power: 15 |
Hi, I am simulating centrifugal compressor flow and vibration, I finished the aerodynamic part, but when i tried to simulate the structural part using (static structural ANSYS), i got an error while updating model, which says (unable to attach geometry).
Appreciate any advise. |
February 5, 2011, 14:02 |
Time for Tech Support?
Simon Pereira
Rep Power: 47 |
That is a good question for Tech support. They may want to see your model. Academics also qualify for tech support. Send your model to Techsupp@ansys.com or go in thru the customer portal (faster).
February 5, 2011, 18:25 |
Mohamed
Rep Power: 15 |
Thanks, for your advise, I managed to solve the problem by editing the model in the Design Modeler (although a tick mark exits) and saving it again (normally not required).
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
