rotation in gambit
Like Tree2Likes
  • 1 Post By morteza08
  • 1 Post By -mAx-
Old   February 13, 2011, 14:48
Default rotation in gambit
morteza08's Avatar
Morteza
morteza08 is on a distinguished road
hi
i have modeled a symmetric 2d impingement jet in gambit... but i assign the y-axis as symmetric line..
when i run it in fluent the y-plus has a illegical value of 150
somebody told me that when you design a symmetric model in gambit, symmetry line must be x-axis. is this true?
if yes ,is there anywayo to rotate my model in gambit for changing the symmetry line to x-axis..
rotation around a axis or any arbitrary line..
thanks
MrDaimon likes this.
morteza08 is offline   Reply With Quote
Old   February 14, 2011, 01:57
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
move one surface: select rotate and give the right rotation's vector (with angle)
Enable connected geometry option.(if your geometry is connected, all you domain will rotate. If not, then you need to fix the connectivity)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 11:05
Gambit Rotation Ed FLUENT 2 December 15, 2006 09:16
