February 25, 2011, 03:54 |
Problem with parallel edges in ICEM
Michal
Rep Power: 19 |
Dear all
I have a question. How can I change bunching on some edges shown bellow, because when I try to do that I can’t and get this message. “User error: cannot reduce the number of intervals to less than 7 because of the number of blocks” Another question. Is it possible to manually change/disable these edges marked with red in such a way that ICEM will not see them as parallel? In other words, the node number on the left on will be 2 and on the right one let’s say 4. However, the nodes number on edge 1 and edge 2 must be equal. |
February 26, 2011, 06:36 |
Simon Pereira
Rep Power: 47 |
Mapped blocks must have the same number of nodes on opposite sides by definition... If a mapped block is next to seven mapped blocks, then there are seven "implied splits" and the node count can't fall below the number of implied splits... I usually extend splits so these implied splits are visible and controllable, then I merge output blocks at the end...
The only way to have different node counts on opposite sides is to change the type of block to free or swept (instead of mapped). You can do this under Edit Block... |
February 28, 2011, 01:44 |
Michal
Rep Power: 19 |
Thank you for your reply Simon
I thought that it is impossible. I will try to extend splits as you suggest. Regards |
November 21, 2015, 08:30 |
How can i make an edge parallel to the curve ?
anand darji
i have a curvature and i want to make an edge parallel to this curvature at some particular distance, how can i do this ?
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Problem with Fluent Parallel | DarrenC | ANSYS | 0 | October 27, 2009 05:38 |
[ICEM] Problem on ICEM. | Eduardo | ANSYS Meshing & Geometry | 1 | October 5, 2009 10:52 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
parallel UDF problem | kerem | FLUENT | 2 | June 20, 2006 06:56 |
