[ICEM] problem of Non-concidence mesh
Old   March 3, 2011, 09:40
Default problem of Non-concidence mesh
jeevan kumar
jeevankumarb is on a distinguished road
Hello ALL,
I had a facing problem on tetra meshing,
I have created volume mesh for an aircraft (Icemcfd V11), since there were some geometry modifications on the fairing of the fuselage; I have created a box around this region so that for the next geometry I can only modify the mesh inside this region.
My first mesh is complete, now for the second mesh, I have deleted the volume cells inside this box and deleted the surface mesh on the surfaces where the modifications were done. Then form the existing surface mesh I have created the surface mesh for the specific part. But the problem it is creating non-coincidence mesh.
How can I avoid this problem? How can I generate coincidence mesh from the previous existing mesh for specific parts?
Hope I am clear to you
Thanks you
jeevankumarb is offline   Reply With Quote
Old   March 4, 2011, 08:47
Default Patch Independent => Respect Line Elements
PSYMN's Avatar
Simon Pereira
Jeevan and I had a conversation on the side about this. I had found out that he was using patch independent tetra to mesh the new region, so I suggested that he use Edit Mesh => Repair => Mesh from edges to fix the problem.
I told him that the respect line elements was for Patch Dependent surface meshing only.
Jeevan found a beta option under the global shell meshing parameters for Patch Independent that let him set the "respect line elements" option and sort out his problem without any mesh editing.
I still haven't tried that option, so thanks to Jeevan for letting me know. Hopefully it helps some of you also.
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[GAMBIT] Problem with mesh. Please Help... maziboss ANSYS Meshing & Geometry 1 September 28, 2009 02:24
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
mesh control problem TUM CFX 4 July 27, 2001 16:17
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 20:26
