March 10, 2016, 23:23 |
blocking 3D wind turbine blade
shuk
Rep Power: 10 |
hello everyone,
i have problem in meshing my wind turbine blade, i have followed the conventional C-grid blocking as shown in https://www.youtube.com/watch?v=EknKVAJGEJ8 but it works best with straight blade. PLEASE have a look at my geometry and advice on how to solve it |
March 10, 2016, 23:29 |
shuk
Rep Power: 10 |
why i couldn't upload my geometry.tin file?
March 12, 2016, 17:48 |
ICEM CFD 3D wing blocking
However, if your blade has a sharp trailing edge and a rounded tip (dome of some sort) you can forget about blocking out a hexa mesh. Either simplify to a truncated (straight cut-with-a-plane) tip or switch to some unstructured meshing approach. Good luck
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube |
March 12, 2016, 23:49 |
shuk
Rep Power: 10 |
hi scipy, thanks for your reply.
Is tetra mesh considered unstructerd? because i just did it for my blade as in the picture. is it possible to make hybrid mesh where the far field hexa and the blade tetra? |
March 13, 2016, 03:47 |
As Far said, this is doable. You can take several approaches to achieve it:
1. a fully conformal hexacore mesh (which is doable in FLUENT Meshing, look into the FLUENT Meshing tutorial guide - there's a tutorial on hybrid viscous meshing for a car shape followed by a hexacore approach tutorial for the same geometry), 2. you can go for a fully conformal merged mesh in ICEM CFD (creating two volumes of fluid, meshing the region near the blade with tetra and inflating prisms, then meshing the rest of the domain by blocking out a fully structured hex mesh and finally merging the two meshes at the interfaces - there's a tutorial in the ICEM CFD tutorial guide on a hybrid tube mesh that deals with this). 3. you could basically repeat the 2nd option but without any merging and just specify a non-conformal interface in FLUENT. However, from looking at your screenshot the first thing you should do is increase the size of the domain because you'll never achieve any results in the solver with a domain this small. Make it at least 3-5 blade lengths in each direction (even more is usually done, but for start 3-5 should be enough).
March 13, 2016, 04:39 |
shuk
Rep Power: 10 |
woaa thanks scipy for your effort,
Actually my domain looks like below where it is 120 degree with the blade in the middle which i just tried to (tetra with hexa core mesh) by following the tutorial from ICEM cfd. for your suggestion is it applicable for this kind of domain? i mean isn't structured mesh require the blocking and the tetra doesn't if i continue with full unstructured mesh will it bear the same result? Last edited by chuky_abc; March 19, 2016 at 17:34. Reason: image hosting problem |
March 13, 2016, 04:51 |
Your domain looks OK (maybe the inlet face could be a bit more distanced from the blade) and that blue region just serves as a "refinement box" for the area around the blade (I'm guessing). This is all OK.
Yes, structured mesh requires blocking. The idea here would be that you mesh the rest of your domain (everything except the blue volume) with hexahedrals and then merge these two meshes at the interfacing zones. This would save up on element count and provide superior wake resolution etc. However, this is a bit complex and unstructured mesh will provide you with decent results if you refine it where it's necessary (around the blade and in the wake of the blade). You could even do these refinements later on in the solver through mesh adaptations based on pressure/velocity gradients. Basically, if you've got enough RAM available to run unstructured tetra meshes of decent element counts, then do this.. it's much simpler and less time consuming.
March 13, 2016, 06:50 |
#9 |
shuk
Rep Power: 10 |
:could you put up suggestions please?
March 13, 2016, 07:28 |
#10 |
I gave you a whole bunch of suggestions... If you want others to do work instead of you, that's over at the CFD Freelancers part of the forum.
March 13, 2016, 11:16 |
#12 | |
shuk
Rep Power: 10 |
thanks scipy and far,
i did what you suggested and here (hexa + tetra), at first it looks OK then it looks distorted when i smoothed it because the quality need to be higher than 0.3 in FLUENT right? also when i set up the boundary condition to periodic (which marked with pink) it failed to load to fluent Quote:
Last edited by chuky_abc; March 19, 2016 at 17:28. Reason: image hosting problem |
March 13, 2016, 17:33 |
#14 |
shuk
Rep Power: 10 |
March 13, 2016, 21:21 |
#15 |
March 17, 2016, 01:25 |
#16 |
shuk
Rep Power: 10 |
hello far and scipy,
thanks for your efforts, btw my lecturer want me to make the mesh to be structured, attached is my geometry file. the pre-mesh have low quality please advice me how to fix it. i have been searching other threads with the same case as mine too.https://www.dropbox.com/s/qcs2r3fnnn...egree.zip?dl=0
March 17, 2016, 03:47 |
#17 | |
March 17, 2016, 06:15 |
#18 |
shuk
Rep Power: 10 |
March 18, 2016, 10:47 |
#19 | |
shuk
Rep Power: 10 |
i have tried your blocking strategy on flat plate version of my blade as practice. the low quality elements seems to be on the hub area,the trail, and floating do i need to adjust the edge parameter or is it because of my domain. i will try it on my real blade and update later. thanks for the video |
March 19, 2016, 10:42 |
#20 |
shuk
Rep Power: 10 |
hello far,
after checking out your videos i have tried my best to block my blade, unfortunately the quality is not satisfying. i have followed your steps carefully. the second o-grid edges doesn't seems to fit into the my airfoil shaped wind turbine, kindly please have a look at my latest mesh and tell me what i did wrong thanks https://www.dropbox.com/s/u3wpwzeprj86dcg/try.zip?dl=0 |
Anlysing and Calculating the power output from a wind turbine blade | mrswordf1sh | FLUENT | 1 | July 13, 2017 01:42 |
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 02:53 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 04:09 |
Wind Turbine Blade rotation | mmd_knr | FLUENT | 1 | August 8, 2012 14:52 |
Wind Turbine Blade Geometry | SeanieB | Main CFD Forum | 0 | November 27, 2009 10:18 |
