[GAMBIT] Mixing faces that constitute a velocity inlet boundary condition
Old   July 10, 2013, 12:05
Default Mixing faces that constitute a velocity inlet boundary condition
Bobby
babakflame is on a distinguished road
Dear Buddies
Hi
I have divided a velocity inlet boundary condition to three faces. There is no problem with the grid. However for crowding out the grid, I want to do an operation like merging these faces so as to observing one circle instead of two half circles and a square in the middle. I had found a solution for this issue; However I have forgot it now. Any hint is appreciated.
More information: It's a 3D grid and after creating the 2D surface grid;I swaped through an identified edge to create the 3D grid.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   July 11, 2013, 07:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't understand your problem.
If you have 3 surfaces and they should set as velocity inlet, then you have 2 options:
-all 3 surfaces as one BC --> you will see only one surface
-each surface as one BC --> you will see 3 surfaces
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 12, 2013, 02:31
Bobby
Hi Max
Let me explain clearer:
when we sweep our faces through a specified edge that has an identified mesh on it; we can create our 3 dimensional grid . After this step, we can see undue lines that sweeping has created in the interior region. My question: Is there any way to get rid of these lines In the interior region? From your response, I infer that after defining boundary conditions properly; these undue lines due to sweeping disappear automatically? Am I right buddy?
Regards
Bobi
Old   July 12, 2013, 03:26
-mAx-'s Avatar
Maxime Perelli
can you post pictures?
Old   July 13, 2013, 03:07
Bobby
Hi max
I have attached a picture. As it can be seen in the picture, After sweeping through the central edge (I have deleted this line); the vertices of the middle square create four lines. Is there any way to get rid of these interior lines.
Although I Know that these interior lines does not disturb in defining boundary conditions.
Regards
Bobi
Old   July 17, 2013, 01:32
-mAx-'s Avatar
Maxime Perelli
if all your volumes are well connected, then the internal surfaces won't give you any problem, since Gambit will treat them as interior.
So connect Faces All
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Radiation interface hinca CFX 15 January 26, 2014 17:11
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
