June 29, 2011, 16:23 |
Negative Volume Help
KJ Lee
Rep Power: 14 |
Hi everyone, I'm meshing a pipe with fittings, with the main pipe having another pipe going through. I just need a little bit of help on how i should move the vertices to fix my negative volume problem. Tried the ICEM smoothing functions which created overlapping/penetrating elements. I think this should be simple fix but I do not know which vertex to move.
Attached are the pictures! |
July 1, 2011, 04:32 |
Rep Power: 18 |
These slim elements on below of elbow are too long relatively to curvature.
Increase the number of elements or try to use as "Edit Edge > Link Edges", "Edit Edge > Split type". |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
