April 14, 2011, 04:24 |
Geometry healing
Sebastian
Rep Power: 15 |
ICEM CFD 13.0 gives me the option to attempt healing on an IGES geometry that I import. Is there any way to check if any healing was actually performed? The .tin files I get are slightly different in size (283.286 bytes without vs 283.280 bytes with healing) but have the same number of surfaces, curves, prescribed points and parts. The log of the import process unfortunately doesn't say anything about whether healing was applied. |
April 16, 2011, 12:22 |
Healing is for connectivity...
Simon Pereira
Rep Power: 47 |
Good question...
Healing shouldn't add or remove entities, it should connect them better. You would need to check the model connectivity in ICEM CFD. Even then, you would only tell if the healing made enough difference to improve the connectivity. I just leave it on and just assume it is better than with it off. However, I also try not to use IGES. It is pretty much the worst format out there (Step is second worst). ACIS is much better. Direct CAD readers are the best. Best regards, Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Display Modes | |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 05:53 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
Healing Import Geometry | Skander | FLUENT | 0 | February 13, 2007 03:21 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
